Résistance à la coercition en vote électronique : conception et analyse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Coercion-resistance in electronic voting : design and analysis
Voting is a central tool for the proper functioning of any democracy. Despite its use in high-stakes elections, electronic voting does not yet provide the same level of security as paper voting. In particular, existing threats such as coercion and vote buying may increase and impact the results.In this thesis, we study academic solutions to address these phenomena, namely the notions of coercion-resistance and receipt-freeness.On these topics, we identify some limitations on the existing definitions and propose new definitions to model more attack scenarios.Besides these theoretical contributions, we propose practical strategies to eliminate certain risks, such as Italian attacks and vote buying. To this end, we develop a toolbox based on multi-party computation primitives, which allow different participants to evaluate a function on encrypted data. This leads to new methods for computing the tally, which counter Italian attacks thanks to the tally-hiding property. These methods can be applied to other types of voting than uninominal voting, such as preferential voting.With respect to vote buying, another contribution of this thesis is to generalize the notion of receipt-freeness so that it is more relateed to this threat, compared to existing notions. We also propose a modular solution that realizes this notion of receipt-freeness, and thus defeat vote buying. This solution relies on new encryption primitives, called traceable encryptions.
Le vote est un outil central au bon fonctionnement de toute démocratie. Malgré son utilisation lors d'élections à grands enjeux, le vote électronique n'apporte pas encore le même niveau de sécurité que le vote papier. En particulier, des menaces déjà existantes telles que la coercition et l'achat de vote risquent de gagner en ampleur et d'impacter les résultats.Au cours de cette thèse, nous étudions les solutions académiques permettant de faire face à ces phénomènes, à savoir les notions de coercion-resistance et de receipt-freeness.Sur ces sujets, nous identifions des limites des définitions existantes et proposons de nouvelles définitions permettant de modéliser de plus larges scénarios d'attaque.En plus de ces améliorations théoriques et pratiques, nous proposons des stratégies efficaces pour éliminer certains risques, comme les attaques à l'italienne et l'achat de vote. Pour cela, nous développons une boîte à outils reposant sur des primitives dites de multi-party computation, qui permettent à différents participants d'évaluer une fonction sur des données chiffrées. Cela nous permet de proposer de nouvelles méthodes de dépouillement offrant une propriété de tally-hiding, qui contrecarre les attaques à l'italienne. Ces méthodes peuvent notamment s'appliquer à d'autres types de scrutin que le vote uninominal, comme par exemple le vote préférentiel.Pour ce qui concerne l'achat de vote, une autre contribution de cette thèse est de généraliser la notion de receipt-freeness afin qu'elle réponde davantage à ce risque, comparée aux notions existantes. Nous proposons par ailleurs une solution modulaire qui permet de réaliser cette notion de receipt-freeness, et donc de mettre à mal les stratégies d'achat de vote. Cette solution s'appuie sur de nouvelles primitives de chiffrement, appelées traceable encryptions.
DDOC_T_2023_0078_YANG.pdf (2.27 Mo) Télécharger le fichier
tel-04206190 , version 1 (13-09-2023)
Paternité
  • HAL Id : tel-04206190 , version 1
Quentin Yang. Résistance à la coercition en vote électronique : conception et analyse. Cryptography and Security [cs.CR]. Université de Lorraine, 2023. English. ⟨NNT : 2023LORR0078⟩. ⟨tel-04206190⟩
106 Consultations
138 Téléchargements
