Learning Visual Language Models for Video Understanding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Apprentissage de Modèles Visuels de Langage pour la Compréhension de Vidéos
The goal of this thesis is to build and train machine learning models that combine the power of natural language processing with visual understanding, enabling a comprehensive and detailed comprehension of the content within videos. First, we propose two scalable approaches to develop video question answering models without the need for costly manual annotation. We automatically generate video question answering data from narrated videos using text-only question-generation models. We then show that a multi-modal transformer trained contrastively on the generated data can answer visual questions in a zero-shot manner. In order to bypass the data generation procedure, we present an alternative approach, dubbed FrozenBiLM, that directly leverages bidirectional masked language models. Second, we develop TubeDETR, a transformer model that can spatially and temporally localize a natural language query in an untrimmed video. Unlike prior spatio-temporal grounding approaches, TubeDETR can be effectively trained end-to-end on untrimmed videos. Third, we present a new model and a new dataset for multi-event understanding in untrimmed videos. We introduce the Vid2Seq model which generates dense natural language descriptions and corresponding temporal boundaries for all events in an untrimmed video by predicting a single sequence of tokens. Moreover, Vid2Seq can be effectively pretrained on narrated videos at scale using transcribed speech as pseudo-supervision. Finally, we introduce VidChapters-7M, a large-scale dataset of user-chaptered videos. Based on this dataset, we evaluate state-of-the-art models on three tasks including video chapter generation. We also show that video chapter generation models transfer well to dense video captioning in both zero-shot and finetuning settings.
L’objectif de cette thèse est de construire et de former des modèles d’apprentissage automatique combinant la puissance du traitement du langage naturel avec la compréhension visuelle, permettant une compréhension complète et détaillée du contenu des vidéos. Premièrement, nous proposons deux nouvelles méthodes pour développer des modèles de réponses aux questions sur des vidéos sans avoir recours à une annotation manuelle coûteuse. Nous générons automatiquement des données de réponses aux questions sur des vidéos à partir de vidéos commentées à l’aide de modèles de génération de questions utilisant uniquement du texte. Nous montrons ensuite qu’un transformateur multi-modal entraîné de manière contrastée sur les données générées peut répondre aux questions visuelles sans entraînement supplémentaire. Afin de contourner la procédure de génération de données, nous présentons une approche alternative, nommée FrozenBiLM, qui exploite directement des modèles de langage masqué bidirectionnels. Deuxièmement, nous développons TubeDETR, un modèle de transformateur capable de localiser spatialement et temporellement une requête en langage naturel dans une vidéo non découpée. Contrairement aux approches spatio-temporelles antérieures, TubeDETR peut être efficacement entraîné de bout en bout sur des vidéos non rognées. Troisièmement, nous présentons un nouveau modèle et un nouvel ensemble de données pour la compréhension de multiple évènements dans les vidéos non découpées. Nous introduisons le modèle Vid2Seq qui génère des descriptions denses en langage naturel et les limites temporelles correspondantes pour tous les événements dans une vidéo non découpée en prédisant une seule séquence de jetons. De plus, Vid2Seq peut être efficacement pré-entraîné sur des vidéos commentées à grande échelle en utilisant les transcriptions de paroles comme pseudo-supervision. Enfin, nous présentons VidChapters-7M, un ensemble de données à grande échelle de vidéos chapitrées par les utilisateurs. Sur la base de cet ensemble de données, nous évaluons des modèles de pointe sur trois tâches, dont la génération de chapitres vidéo. Nous montrons également que les modèles de génération de chapitres vidéo se transfèrent bien au sous-titrage vidéo dense.
PhD_Yang_Antoine_final.pdf (42.6 Mo) Télécharger le fichier
tel-04307117 , version 1 (25-11-2023)
tel-04307117 , version 2 (28-11-2023)
  • HAL Id : tel-04307117 , version 1
Antoine Yang. Learning Visual Language Models for Video Understanding. Computer Vision and Pattern Recognition [cs.CV]. Ecole Normale Superieure de Paris - ENS Paris, 2023. English. ⟨NNT : ⟩. ⟨tel-04307117v1⟩
346 Consultations
15 Téléchargements
