Lattice-based Signatures in the Fiat-Shamir Paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Signatures Fondées sur les Réseaux Euclidiens dans le Paradigme de Fiat-Shamir
The Fiat-Shamir paradigm enables the systematic design of signature schemes from identification protocols. The latter are three-moves interactive protocols between a prover holding onto some secret information and a verifier with a correlated public information. There are efficient and elegant designs for them and as the Fiat-Shamir transform is simple and flexible, its popularity is easily explained. Unfortunately, its use in the lattice setting turns out to be more difficult and researchers usually rely on a variant, the Fiat-Shamir with aborts transform. This thesis proposes a study of this paradigm and its use in conjunction with Euclidean lattices. First, we recover the security of this transform after identifying flaws in the previous security reductions. This is also a pretense to study the runtime of the signature as well as discuss the zero-knowledge flavor satisfied by Lyubashevsky’s scheme, the most famous aborting identification protocols based on Euclidean lattices. We then move on to study it in more details. This scheme relies on a generic technique called rejection sampling, and can be adapted to work with a wide range of pairs of distributions to sample from and to reject to, as long as these two dis- tributions are “close”. Under a target average number of iterations of the scheme, we minimize the average Euclidean norm of the final signature, by wisely choos- ing the pair of source and target distributions. This directly decreases the size of the signature and also makes forgery attacks harder, allowing for smaller parameter choices. Next we propose HAETAE, an implementation of the bimodal, uniform over Eu- clidean balls, version of Lyubashevsky’s signature scheme. Let us quickly compare it with the two lattice-based signature schemes selected by NIST for standardisation. Contrary to Dilithium, which aimed for easy implementation, we aimed for low sig- nature sizes. This results in a scheme with up to 40% smaller signature sizes than Dilithium but up to 8 times signing runtime. When compared to Falcon, however, we still have bigger signature sizes but lower signing runtime. Our implementation is constant-time and relies only on fixed-point arithmetic. Finally, we propose a novel way to avoid rejection sampling by using discrete Gaussian convolutions. Contrary to flooding, this solution appears to preserve the signature and verification key size of the signature scheme and can even be proven to be asymptotically smaller. While it requires sampling from an elliptical discrete Gaussian, this distribution can be made independent from the message. Our tech- nique can be seen as a generalisation of the bimodal technique, where instead of relying on two centers, we randomly pick one over a line with a discrete Gaussian distribution. This center corrects the distribution of the first message, making the last message independent from the secret, which was the critical problem that led to the introduction of rejection sampling in the first place.
Le paradigme de Fiat-Shamir permet la création systématique de schémas de signa- ture à partir de protocoles d’identification. Ces derniers sont des protocoles interactifs en trois messages, entre un prouveur possédant une information secrète et un vérifi- cateur avec une information publique corrélée. La transformation de Fiat-Shamir est simple et flexible, ce qui explique sa popularité, notamment lorsqu’elle est combinée avec des protocoles d’identification efficaces. Malheureusement, son utilisation dans le cadre de la cryptographie fondée sur les réseaux Euclidiens se révèle plus compli- quée, et on lui préfère sa variante dite avec rejet. Cette thèse propose une étude de cette variante et de son utilisation en conjonction avec les réseaux Euclidiens. Nous commençons par recouvrer sa sécurité après avoir identifié des erreurs dans les pré- cédentes preuves de sécurité proposées. On étudie aussi le temps d’exécution d’une signature ainsi que les propriétés de non-divulgation de connaissance du protocole de Lyubahsevsky, qui est le plus célèbre à reposer sur les réseaux Euclidiens. Nous l’étudions ensuite plus en détail. Ce protocole repose sur l’échantillonnage par rejet, qui peut être utilisée avec une très grande variété de paires “proches” de distributions : on échantillonne depuis l’une pour rejeter vers l’autre. Étant donné un nombre moyen d’itérations du protocole, nous minimisons la norme Euclidienne moyenne de la signature résultante, en choisissant soigneusement la paire de distribu- tions source et cible. Cela diminue la taille de la signature, et la rend plus résistante aux attaques, ce qui permet de réduire les paramètres pour la même sécurité. Nous proposons ensuite HAETAE, une implémentation de la version bimodale avec des distributions uniformes sur des boules Euclidiennes de la signature de Lyu- bashevsky. Si nous la comparons rapidement avec les signatures réseaux sélectionnées par le NIST pour être standardisées, on s’aperçoit que nous avons des tailles de si- gnatures près de 40% plus petite que Dilithium, même si nous signons jusqu’à 8 fois plus lentement. Cela reste pourtant plus grand en taille mais plus rapide en vitesse de signature que Falcon. De plus, notre implémentation est en temps constant et n’utilise que de l’arithmétique à virgule fixe. Enfin, nous proposons d’éviter l’échantillonnage par rejet en utilisant à la place des convolutions de Gaussiennes discrètes. Contrairement aux autres techniques connues, cette solution semble préserver les tailles de signatures et de clés de vé- rification du protocole pour des paramètres concrets, et elles sont même meilleures asymptotiquement. Bien que cette technique requiert d’échantillonner à partir d’une Gaussienne discrète elliptique, celle-ci est indépendante du message. Pour corriger cette distribution du premier message, un centre aléatoire est choisi et le résultat sera indépendant du secret, ce qui est le problème critique qui avait mené à l’introduction du rejet en premier lieu.
main.pdf (2.38 Mo) Télécharger le fichier
tel-04320790 , version 1 (04-12-2023)
  • HAL Id : tel-04320790 , version 1
Julien Devevey. Lattice-based Signatures in the Fiat-Shamir Paradigm. Computer Science [cs]. Ecole Normale Supérieure de Lyon, 2023. English. ⟨NNT : 2023ENSL0052⟩. ⟨tel-04320790⟩
100 Consultations
71 Téléchargements
