Visual Servoing of the Orientation of an Earth Observation Satellite - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Asservissement visuel de l’orientation d’un satellite d’observation de la Terre
Maxime Robic
  • Fonction : Auteur
  • PersonId : 1160852
This thesis aims to develop vision- based control laws for a low orbit observation satellite capable of moving on its three rotational degrees of freedom. Indeed, Earth observation satellites are used to precisely point their sensor toward the Earth’s surface, and traditional control methods face challenges due to orbital motion and external perturbations becoming intense in low Earth orbits. Real-time satellite attitude guidance through vision sensor feedback can offer more features to improve the robustness, accuracy, and flexibility of the pointing, and allows for more complex missions, such as tracking a moving target. Visual servoing, a vision-based closed- loop control approach, is appealing in this context. Visual servoing has indeed already proven its effectiveness in performing various robotic tasks (navigation, manipulation, ob- servation..), with recent applications to space robotics. By defining the mission of an obser- vation satellite as a visual servoing task, it becomes possible to apply these different techniques to precisely control its orientation. This thesis proposes personalized visual control laws to address issues related to fast satellite motion, its mechanical constraints, on-board visual tracking of moving targets, and image quality, specifically mitigating motion blur during an acquisition.
Cette thèse vise à développer des lois de commande basées vision pour un satellite d’observation en basse orbite capable de s’orienter sur ses trois degrés de liberté. En effet, les satellites d’observation de la Terre doivent pointer précisément leur capteur vers la surface de la Terre, et les méthodes de commande traditionnelles font face à des problèmes en raison de la vitesse orbitale du satellite et des perturbations externes devenant fortes en orbite terrestre basse. Un guidage en temps réel de l’attitude d’un satellite à partir des informations d’un capteur de vision peut offrir davantage de fonctionnalités pour améliorer la robustesse, la précision et la flexibilité du pointage, et permettre des missions plus complexes, telles que le suivi d’un objet en mouvement, ce qui restait jusqu’à présent un problème ouvert. L’asservissement visuel est une approche prometteuse dans ce contexte. Elle a en effet déjà prouvé son efficacité pour effectuer des tâches robotiques (déplacement, manipulation, observation,..), avec de récentes applications à la robotique spatiale. En formulant la mission d’un satellite comme une tâche d’asservissement visuel, il devient possible d’appliquer ces techniques pour contrôler précisément son orientation. Cette thèse propose des lois d’asservissement visuel pour résoudre les problèmes liés aux mouvements rapides du satellite, à ses contraintes mécaniques, à la poursuite de cibles mobiles, et à la qualité de l’image, en atténuant spécifiquement le flou de mouvement lors d’une acquisition.
2023_phd_robic.pdf (42.42 Mo) Télécharger le fichier
tel-04394522 , version 1 (15-01-2024)
tel-04394522 , version 2 (29-01-2024)
Paternité
  • HAL Id : tel-04394522 , version 1
Maxime Robic. Visual Servoing of the Orientation of an Earth Observation Satellite. Automatic. Université de Rennes, 2023. English. ⟨NNT : ⟩. ⟨tel-04394522v1⟩
57 Consultations
2 Téléchargements
