Identification of biological ligands of uranium in Danio rerio gonads : Impact on their function
Identification des ligands biologiques de l'uranium dans les gonades de Danio rerio - Impact sur leur fonctionnalité
Uranium (U) is naturally presents at trace level (µg.L-1) in aquatic environment; its concentration can increase up to a few mg.L-1 due to human activities. Several ecotoxicological studies have shown uranium toxicity in contaminated zebrafishes Danio rerio, e.g. oxidative stress, genotoxicity and reprotoxicity (i.e. lower number of spawn and eggs laid) but mechanisms are not well known.The objective of this study is to contribute to the understanding of uranium reprotoxicity by elucidating the disrupted molecular mechanisms after contamination. Therefore, investigations have been carried out on ovaries from reproduced (R) and non-reproduced (NR) zebrafishes after waterborne exposure in laboratory conditions at environmentally relevant concentrations.This project was divided into two parts. Firstly, analytical investigations were carried out to continue the development of non-denaturing methods for U-protein identification by coupling separative techniques (size exclusion chromatography SEC, off gel electrophoresis OGE) with elemental (ICP MS) and molecular (ESI MS) sensitive mass spectrometry detection. Secondly, studies of U reprotoxicity were investigated by studying i) native U-protein complexes (metallomics approach) and ii) differential analysis of protein expression (proteomics approach)Analytical developments allowed keeping the physiological and non-denaturing extraction buffer for OGE separation step, improving U recovery. In ecotoxicology, the major results showed that ovary is an U accumulating organ and that the reproduction status modifies the accumulation level (R
L’uranium (U) est naturellement présent à l’état de trace dans l’eau (µg.L-1), sa concentration pouvant atteindre localement quelques mg.L-1 du fait des activités anthropiques. Plusieurs études écotoxicologiques sur Danio rerio ont mis en évidence la toxicité, e.g. le stress oxydant, la génotoxicité mais aussi la reprotoxicité (i.e. moins de pontes et d’œufs pondus chez les poissons contaminés) de l’U dont les mécanismes ne sont pas connus.L’objectif de cette étude est de contribuer à la compréhension de la reprotoxicité de l’U par l’élucidation de mécanismes moléculaires perturbés après contamination. Pour cela, des investigations ont été menées sur les ovaires de poissons zèbre Danio rerio, reproduits (R) ou non (NR), après exposition par voie directe en condition de laboratoire à des concentrations représentatives d’environnements contaminés.Ce travail de thèse a été divisé en deux volets. Un premier volet analytique avait pour but la poursuite des développements de méthodes pour l’identification des complexes U-protéines en condition non dénaturante, autour du couplage de techniques de séparation (chromatographie d’exclusion stérique SEC, électrophorèse hors gel OGE) et de détection sensible par spectrométrie de masse élémentaire (ICP MS) et moléculaire (ESI MS). Le second volet a été dédié à l’étude de la reprotoxicité de l’U à l’échelle moléculaire, avec i) l’étude des complexes natifs U-protéines (approche métallomique), et ii) l’analyse différentielle de l’expression des protéines (approche protéomique).Les développements analytiques ont permis de garder le tampon physiologique et non dénaturant d’extraction pour l’étape de séparation OGE, améliorant le taux de recouvrement en U. En écotoxicologie, les principaux résultats montrent que l’ovaire est un organe accumulateur de l’U et que le statut de reproduction a une influence sur le niveau d’accumulation (R
HAL IRSN : Connect in order to contact the contributor
https://irsn.hal.science/tel-04441366
Submitted on : Tuesday, February 6, 2024-1:37:17 PM
Last modification on : Saturday, March 23, 2024-3:26:41 AM
Dates and versions
Identifiers
- HAL Id : tel-04441366 , version 1
Cite
Yvan Eb-Levadoux. Identification des ligands biologiques de l'uranium dans les gonades de Danio rerio - Impact sur leur fonctionnalité. Chimie analytique. Université de Pau et des Pays de l'Adour, 2017. Français. ⟨NNT : 2017PAUU3016⟩. ⟨tel-04441366⟩
6
View
Download
