The semiring-based provenance framework for graph databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
Provenance à base de semi-anneaux pour les bases de données graphes
Yann Ramusat
  • Fonction : Auteur
  • PersonId : 1363775
  • IdRef : 276327527
The growing amount of data collected by sensors or generated by human interaction has led to an increasing use of graph databases, an efficient model for representing intricate data. Techniques to keep track of the history of computations applied to the data inside classical relational database systems are also topical because of their application to enforce Data Protection Regulations (e.g., GDPR). Our research work mixes the two by considering a semiring-based provenance model for navigational queries over graph databases. We first present a comprehensive survey on semiring theory and their applications in different fields of computer sciences, geared towards their relevance for our context. From the richness of the literature, we notably obtain a lower bound for the complexity of the full provenance computation in our setting. In a second part, we focus on the model itself by introducing a toolkit of provenance-aware algorithms, each targeting specific properties of the semiring of use. We notably introduce a new method based on lattice theory, permitting an efficient provenance computation for complex graph queries. We propose an open-source implementation of the above-mentioned algorithms, and we conduct an experimental study over real transportation networks of large size, witnessing the practical efficiency of our approach in practical scenarios. We finally consider how this framework is positioned compared to other provenance models, such as the semiring-based Datalog provenance model. We make explicit how the methods we applied for graph databases can be extended to Datalog queries, and we show how they can be seen as an extension of the semi-naïve evaluation strategy. To leverage this fact, we extend the capabilities of SOUFFLÉ, a state-of-the-art Datalog solver, to design an efficient provenance-aware Datalog evaluator. Experimental results based on our open-source implementation entail the fact this approach stays competitive with dedicated graph solutions, despite being more general. In a final round, we discuss on some research ideas for improving the model, and state open questions raised by our work.
L'augmentation du volume de données collectées par des capteurs et générées par des interactions humaines a mené à l'utilisation des bases de données orientées graphes en tant que modèle de représentation efficace pour les données complexes. Les techniques permettant de tracer les calculs qui ont été appliqués aux données au sein d'une base de données relationnelle classique sont sur le devant de la scène, notamment grâce à leur utilité pourfaire respecter les régulations sur les données privées telles que le RGPD en Union européenne. Notre travail de recherche croise ces deux problématiques en s'intéressant à un modèle de provenance à base de semi-anneaux pour les requêtes navigationnelles. Nous commençons par présenter une étude approfondie de la théorie des semi-anneaux et de leurs applications au sein des sciences informatiques en se concentrant sur les résultats ayant un intérêt direct pour notre travail de recherche. La richesse de la littérature sur le domaine nous a notamment permis d'obtenir une borne inférieure sur la complexité de notre modèle. Dans une seconde partie, nous étudions le modèle en lui-même et introduisons un ensemble cohérent d'algorithmes permettant d'effectuer des calculs de provenance et adaptés aux propriétés des semi-anneaux utilisés. Nous introduisons notablement une nouvelle méthode basée sur la théorie des treillis permettant de calculer la provenance pour des requêtes complexes. Nous proposons une implémentation open-source de ces algorithmes et faisons une étude expérimentale sur de larges réseaux de transport issus de la vie réelle pour attester de l'efficacité pratique de notre approche. On s'intéresse finalement au positionnement de ce cadre de travail par rapport à d'autres modèles de provenance à base de semi-anneaux. Nous nous intéressons à Datalog en particulier. Nous démontrons que les méthodes que nous avons développées pour les bases de données orientées graphes peuvent se généraliser sur des requêtes Datalog. Nous montrons de plus qu'elles peuvent être vues comme des généralisations de la méthode semi-naïve. En se basant sur ce fait-là, nous étendons les capacités de SOUFFLÉ, un évaluateur Datalog appartenant à l'état de l'art, afin d'effectuer des calculs de provenance pour des requêtes Datalog. Les études expérimentales basées sur cette implémentation open-source confirment que cette approche reste compétitive avec les solutions spécifiques pour les graphes, mais tout en étant plus générale. Nous terminons par une discussion sur les améliorations possibles du modèle et énonçons les questions ouvertes qui ont été soulevées au cours de ce travail.
Ramusat_2022_These.pdf (1.33 Mo) Télécharger le fichier
tel-04505107 , version 1 (13-12-2022)
tel-04505107 , version 2 (14-03-2024)
  • HAL Id : tel-04505107 , version 2
Yann Ramusat. The semiring-based provenance framework for graph databases. Databases [cs.DB]. Université Paris sciences et lettres, 2022. English. ⟨NNT : 2022UPSLE022⟩. ⟨tel-04505107v2⟩
254 Consultations
100 Téléchargements
