Sanctuaires et territoires en Étrurie méridionale : le cas du lac de Bolsena entre Volsinies, Vulci et Tarquinia du IVe s. av. n. è. au Ier s. de n. è. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Sanctuaries and territories in Southern Etruria : the case of Lake Bolsena between Volsinii, Vulci and Tarquinia from the 4th century BC to the 1st century AD.
Martin Jaillet
  • Fonction : Auteur
  • PersonId : 1376155
  • IdRef : 264746317
This thesis deals with the question of rural sanctuaries and the religious landscape of a part of southern Etruria, around Lake Bolsena (Lazio), from the 4th century B.C., which marks the beginning of military confrontations between Rome and Etruria, until the 1st century A.D., when the Etruscan culture and language gradually faded, especially after the administrative reorganizations of the imperial period.The aim is both to study the evolution of Etruscan cults, characterized by the long infusion of Roman culture in the region, by showing that they continue well beyond the conquest, and to develop a critical thought on the concepts used by contemporary research on the matter of sanctuaries, by articulating it with issues related to the territory, in particular the ambiguous category of frontier sanctuaries in Etruscology.This work is based both on historiographical data and on the analysis of an unpublished archaeological material discovered in the sanctuary of Piana del Lago (Montefiascone), which the author has co-directed the excavation between 2020 and 2022.
Cette thèse s'intéresse à la question des sanctuaires ruraux et au paysage religieux d'une partie de l'Étrurie méridionale, autour du lac de Bolsena (Latium), depuis le IVe s. av. n. è., qui marque le début des confrontations militaires entre Rome et l'Étrurie, jusqu'au Ier s. de n. è., lorsque la culture et la langue étrusques disparaissent progressivement, en particulier après les réorganisations administratives de l'époque impériale. L'objectif est tout à la fois d'étudier l'évolution des cultes étrusques, marquée par l'infusion longue de la culture romaine dans la région, en montrant que ces derniers se poursuivent bien au-delà de la conquête, et de développer une réflexion critique sur les concepts mobilisés par la recherche contemporaine sur la question des sanctuaires, en l'articulant avec des problématiques liées au territoire, en particulier la catégorie ambiguë des sanctuaires de frontière en étruscologie. Pour cela, ce travail se fonde tout à la fois sur l'étude des données historiographiques et sur l'exploitation d'un mobilier archéologique inédit mise au jour dans le sanctuaire de Piana del Lago (Montefiascone), dont l'auteur a co-dirigé la fouille entre 2020 et 2022.
2023UPSLP008_archivage.pdf (25.77 Mo) Télécharger le fichier
tel-04550766 , version 1 (18-04-2024)
  • HAL Id : tel-04550766 , version 1
Martin Jaillet. Sanctuaires et territoires en Étrurie méridionale : le cas du lac de Bolsena entre Volsinies, Vulci et Tarquinia du IVe s. av. n. è. au Ier s. de n. è.. Histoire. Université Paris sciences et lettres, 2023. Français. ⟨NNT : 2023UPSLP008⟩. ⟨tel-04550766⟩
0 Consultations
0 Téléchargements
