3D recοnstructiοn of particles in a flow by interferοmetric imaging
Reconstruction 3D de particules dans un écoulement par imagerie interférométrique
For many industrial or environmental applications, it is important to measure the size and volume of irregularly shaped particles. This is for example the case in the context of aircraft icing which occurs during flights, where it is necessary to measure in situ the water content and the ice content in the troposphere in order to detect and avoid risk areas. Our interest has been on interferometric out-of-focus imaging, an optical technique offering many advantages (wide measurement field, extended range of sizes studied [50 μm: a few millimeters], distance particle / measuring device several tens of centimeters ...). During this thesis, we showed that the 3D reconstruction of a particle can be done from a set of three interferometric images of this particle (under three perpendicular viewing angles). This can be done using the error reduction (ER) algorithm which allows to obtain the function f(x,y) from the measurements of the modulus of its 2D Fourier transform |F(u,v)| , by reconstructing the phase of its 2D Fourier transform. The implementation of this algorithm allowed us to reconstruct the shape of irregular particles from their interferometric images. Experimental demonstrations were carried out using a specific assembly based on the use of a micro-mirror array (DMD) which generates the interferometric images of programmable rough particles. The results obtained are very encouraging. The volumes obtained remain quite close to the real volume of the particle and the reconstructed 3D shapes give us a good idea of the general shape of the particle studied even in the most extreme cases where the orientation of the particle is arbitrary. Finally, we showed that an accurate 3D reconstruction of a "programmed" rough particle can be performed from a set of 120 interferometric images.
Pour de nombreuses applications industrielles ou environnementales, il est important de mesurer la taille et le volume de particules de formes irrégulières. C'est par exemple le cas dans le cadre du givrage des aéronefs qui se produit durant les vols, où il est nécessaire de mesurer in-situ la teneur en eau et la teneur en glace dans la troposphère afin de détecter et d’éviter les zones à risques. Notre intérêt s’est porté sur l’imagerie interférométrique en défaut de mise au point, une technique optique offrant de nombreux avantages (large champ de mesure, gamme de tailles étudiée étendue [50 μm : quelques millimètres], distance particule/appareil de mesure de plusieurs dizaines de centimètres…). Au cours de ces travaux de thèse, nous avons montré que la reconstruction 3D d'une particule peut se faire à partir d'un ensemble de trois images interférométriques de cette particule (sous trois angles de vue perpendiculaires). Cela peut être fait en utilisant l'algorithme de réduction d'erreur (ER) qui permet d'obtenir la fonction f(x,y) à partir des mesures du module de sa transformée de Fourier 2D |F(u,v)|, en reconstruisant la phase de sa transformée de Fourier 2D. La mise en œuvre de cet algorithme nous a permis de reconstruire la forme de particules irrégulières à partir de leurs images interférométriques. Des démonstrations expérimentales ont été réalisées à l'aide d'un montage spécifique basé sur l'utilisation d’une matrice de micro-miroirs (DMD) qui génère les images interférométriques de particules rugueuses programmables. Les résultats obtenus sont très encourageants. Les volumes obtenus restent assez proches du volume réel de la particule et les formes 3D reconstruites nous donnent une bonne idée de la forme générale de la particule étudiée même dans les cas les plus extrêmes où l'orientation de la particule est quelconque. Enfin, nous avons montré qu'une reconstruction 3D précise d'une particule rugueuse "programmée" peut être effectuée à partir d'un ensemble de 120 images interférométriques.
