Les stratégies et l'environnement dans la performance sportive de haut niveau en triathlon - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Strategies and the environment in top-level sports performance : triathlon
This thesis work revolves around the analysis of inter-individual factors affecting performance and their connection with environmental factors within the context of triathlon, particularly focusing on the triathlon formats featured in the Olympic Games. Performances in triathlon races, where triathletes interact with each other, as seen in the short-distance triathlon formats (super-sprint, sprint, and standard), depend on the optimal utilization of individual capacities and the adaptation of effort to the race dynamics. The discipline of short-distance triathlon has evolved both in terms of regulations and technology over the past two decades. Therefore, the research objective was to understand race dynamics in these short formats based on the profiles of the participating triathletes and to quantify the performance levels of each athlete while taking into account the competition, which is the most consistent parameter across different races. The initial studies (1 and 2) focused on the innovative format of mixed relays introduced in the 2020 Tokyo Olympics. This ultra-short format involves race dynamics centered around maintaining position and high proximity among athletes. We observed the strategies adopted by teams and identified the profiles of triathletes corresponding to each relay.Subsequently, our research shifted towards the standard format (studies 3 and 4), also featured in the Olympics and compulsory for relay athletes. In these studies, we aimed to estimate the level of each athlete using points exchange system based on the probabilities of victory and defeat between each pair of athletes. This system allowed us to assess the density of competition in a race and the target performance of an athlete. Furthermore, by connecting it to course typology, we were able to observe race group dynamics and estimate the probability of a successful breakaway after the swimming and cycling segments.
Ce travail de thèse se concentre sur l'analyse des facteurs interindividuels de la performance et de leurs liens avec les facteurs environnementaux dans la discipline du triathlon, en particulier sur les formats de triathlon présents aux Jeux Olympiques. Les performances dans les courses de triathlon, où les triathlètes interagissent les uns avec les autres, comme c'est le cas sur les parcours de triathlon de courte distance (super-sprint, sprint et standard), dépendent de l'utilisation optimale des capacités individuelles ainsi que de l'adaptation de l'effort à la dynamique de la course. La discipline du triathlon courte distance a évolué sur le plan réglementaire et technologique au cours des vingt dernières années. Par conséquent, l'objectif de cette recherche était de comprendre les dynamiques de course sur ces formats courts en fonction des profils de triathlètes présents, et de quantifier les niveaux de performance de chacun en tenant compte de la concurrence, qui est le paramètre le plus similaire entre chaque course. Les premières études (1 et 2) se sont penchées sur le format novateur du relais mixte, qui a été introduit aux Jeux Olympiques de Tokyo 2020. Ce format ultra-court propose une dynamique de course axée sur la préservation de la position et implique une proximité élevée entre les athlètes. Nous avons ainsi observé les stratégies mises en place par les équipes et identifié les profils de triathlètes correspondant à chaque relais. Dans un second temps, nos recherches se sont orientées vers le format standard (études 3 et 4), également présent aux Jeux Olympiques et obligatoirement concouru par les athlètes du relais. Dans ces études, nous avons cherché à estimer le niveau de chaque athlète en utilisant un système d'échange de points en fonction des probabilités de victoire et de défaite entre chaque paire d'athlètes. Ce système nous a permis d'évaluer la densité de la concurrence lors d'une course et la performance cible d'un athlète. De plus, en le reliant à la typologie des parcours, nous avons pu observer les dynamiques de groupe en course et estimer la probabilité de réussite d'une échappée à l'issue de la natation et de la partie cycliste.
va_Ledanois_Thibaut.pdf (4.02 Mo) Télécharger le fichier
tel-04556826 , version 1 (23-04-2024)
  • HAL Id : tel-04556826 , version 1
Thibaut Ledanois. Les stratégies et l'environnement dans la performance sportive de haut niveau en triathlon. Sciences du Vivant [q-bio]. Université Paris Cité, 2023. Français. ⟨NNT : 2023UNIP7101⟩. ⟨tel-04556826⟩
0 Consultations
0 Téléchargements
