Etude de la modulation de l'expression des aquaporines-4 par un inhibiteur de kinases dépendantes de cyclines en cas d'accident vasculaire cérébral chez le rat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2023
Study of the modulation of aquaporin-4 expression by a cyclin-dependent kinase inhibitor in ischemic rat model
Cerebral edema is one of the deadliest complications of ischemic stroke for which there is currently no pharmaceutical treatment. Aquaporin-4 (AQP4), a water- channel polarized at the astrocyte endfoot, is known to be highly implicated in cerebral edema. We previously showed in randomized studies that (S)-roscovitine, a cyclin-dependent kinase inhibitor, reduced cerebral edema in the case of ischemic stroke. The aim of this thesis was to understand the mechanisms behind the anti- edema effect of (S)-roscovitine by studying its impact on the expression of AQP4. We demonstrated that (S)-roscovitine reduces cerebral edema within the first 24 hours of stroke by increasing the expression of AQP4 at the astrocytic endfeet. This increase was associated with a decrease in non- perivascular AQP4, suggesting a relocation effect of the channel. This polarized expression is mediated by its interaction with α1-syntrophin, an adaptor protein belonging to its membrane anchoring complex. We showed that (S)-roscovitine promotes the interaction between AQP4 and α1- syntrophin. This interaction is negatively correlated with cerebral edema. These findings suggest that (S)-roscovitine could represent a promising option as a potential treatment for cerebral edema in ischemic stroke and as a modulator of AQP4.
L’œdème cérébral est l’une des complications les plus mortelles de l’accident ischémique cérébral (AIC), contre laquelle il n’existe aucun traitement pharmaceutique. L’aquaporine-4 (AQP4), un canal perméable à l’eau exprimé dans les pieds astrocytaires qui bordent les vaisseaux sanguins cérébraux, est impliquée dans la formation de l’œdème. Notre équipe a précédemment montré dans des études randomisées que la (S)-roscovitine, un inhibiteur de kinases dépendantes des cyclines, réduisait l’œdème en cas d’ischémie cérébrale. L’objectif de cette thèse a été de comprendre les mécanismes de l’effet anti-œdémateux de la (S)-roscovitine en étudiant son impact sur l’expression de l’AQP4. Nous avons montré que la (S)-roscovitine réduisait l’œdème cérébral dès les premières 24 heures de l’AlC en augmentant l’expression de l’AQP4 aux pieds astrocytaires. Cette augmentation était associée à une diminution des AQP4 non-périvasculaires, suggérant un effet de relocalisation du canal. Cette expression polarisée est médiée par son interaction avec l’α1 - syntrophine, une protéine adaptatrice appartenant à son complexe d’ancrage à la membrane. Nous avons montré que la (S)-roscovitine favorisait l’interaction entre l’AQP4 et l’α1-syntrophine. Cette interaction est corrélée négativement à l’œdème cérébral. Ces découvertes suggèrent que la (S)-roscovitine pourrait représenter une option prometteuse en tant que traitement potentiel de l'œdème cérébral dans l’AlC et en tant que modulateur de la fonction de l'AQP4.
These-2023-SVS-Genetique_genomique_bioinformatique-MOELO_Cloe.pdf (196.98 Mo) Télécharger le fichier
tel-04557623 , version 1 (24-04-2024)
  • HAL Id : tel-04557623 , version 1
Cloé Moëlo. Etude de la modulation de l'expression des aquaporines-4 par un inhibiteur de kinases dépendantes de cyclines en cas d'accident vasculaire cérébral chez le rat. Génomique, Transcriptomique et Protéomique [q-bio.GN]. Université de Bretagne occidentale - Brest, 2023. Français. ⟨NNT : 2023BRES0089⟩. ⟨tel-04557623⟩
0 Consultations
0 Téléchargements
