Weak approximation errors for stochastic differential equations with non-regular drift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We consider an Euler-Maruyama type approximation method for a stochastic differential equation (SDE) with a discontinuous drift and regular diffusion coefficient. The method regularizes the drift coefficient within a certain class of functions and then the Euler-Maruyama scheme for the regularized scheme is used as an approximation. This methodology gives two errors, the first is the error of regularization of the drift coefficient within a given class of parametrized functions and the second is the error of the regularized Euler-Maruyama scheme. After an optimization procedure with respect to this parameter we obtain various rates, which improve other known results.
kohatsu-lejay-yasuda-V2.pdf (256.96 Ko) Télécharger le fichier
hal-00840211 , version 1 (01-07-2013)
hal-00840211 , version 2 (29-05-2015)
hal-00840211 , version 3 (12-01-2016)
hal-00840211 , version 4 (02-09-2016)
hal-00840211 , version 5 (06-07-2017)
  • HAL Id : hal-00840211 , version 2
Arturo Kohatsu-Higa, Antoine Lejay, Kazuhiro Yasuda. Weak approximation errors for stochastic differential equations with non-regular drift. 2015. ⟨hal-00840211v2⟩
748 Consultations
3289 Téléchargements
