Weak rate of convergence of the Euler-Maruyama scheme for stochastic differential equations with non-regular drift - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2017
We consider an Euler-Maruyama type approximation method for a stochastic differential equation (SDE) with a non-regular drift and regular diffusion coefficient. The method regu-larizes the drift coefficient within a certain class of functions and then the Euler-Maruyama scheme for the regularized scheme is used as an approximation. This methodology gives two errors. The first one is the error of regularization of the drift coefficient within a given class of parametrized functions. The second one is the error of the regularized Euler-Maruyama scheme. After an optimization procedure with respect to the parameters we obtain various rates, which improve other known results.
kohatsu-lejay-yasuda_Finale.pdf (282.02 Ko) Télécharger le fichier
hal-00840211 , version 1 (01-07-2013)
hal-00840211 , version 2 (29-05-2015)
hal-00840211 , version 3 (12-01-2016)
hal-00840211 , version 4 (02-09-2016)
hal-00840211 , version 5 (06-07-2017)
Arturo Kohatsu-Higa, Antoine Lejay, Kazuhiro Yasuda. Weak rate of convergence of the Euler-Maruyama scheme for stochastic differential equations with non-regular drift. Journal of Computational and Applied Mathematics, 2017, 326C, pp.138-158. ⟨10.1016/j.cam.2017.05.015⟩. ⟨hal-00840211v5⟩
748 Consultations
3289 Téléchargements
