Fitting ideals and multiple-points of surface parameterizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Given a birational parameterization of an algebraic surface S in the projective space, the purpose of this paper is to investigate the sets of points on S whose preimage consists in k or more points, counting multiplicities. They are described explicitly in terms of Fitting ideals of some graded parts of the symmetric algebra associated to this parameterization.
SingRatSurfaces.pdf (528.95 Ko) Télécharger le fichier
hal-00874221 , version 1 (17-10-2013)
hal-00874221 , version 2 (17-12-2014)
Nicolás Botbol, Laurent Busé, Marc Chardin. Fitting ideals and multiple-points of surface parameterizations. 2013. ⟨hal-00874221v1⟩
354 Consultations
396 Téléchargements
