Fitting ideals and multiple points of surface parameterizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra Année : 2014
Given a birational parameterization f of an algebraic surface S, the purpose of this paper is toinvestigate the sets of points on S whose preimage consists in kor more points, counting multiplicities. These points are described explicitly interms of Fitting ideals of some graded parts of the symmetric algebraassociated to the parameterization f. To obtain this description, weshow that the degree and dimension of a fiber could be computed bycomparing the drop of rank of two explicit (representation) matrices associated to f.
SingRatSurfacesMRep-v3.pdf (390.69 Ko) Télécharger le fichier
hal-00874221 , version 1 (17-10-2013)
hal-00874221 , version 2 (17-12-2014)
Nicolás Botbol, Laurent Busé, Marc Chardin. Fitting ideals and multiple points of surface parameterizations. Journal of Algebra, 2014, 420, pp.486-508. ⟨10.1016/j.jalgebra.2014.07.028⟩. ⟨hal-00874221v2⟩
354 Consultations
396 Téléchargements
