On the strong consistency of the kernel estimator of extreme conditional quantiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Nonparametric regression quantiles can be obtained by inverting a kernel estimator of the conditional distribution. The asymptotic properties of this estimator are well-known in the case of ordinary quantiles of fixed order. The goal of this paper is to establish the strong consistency of the estimator in case of extreme conditional quantiles. In such a case, the probability of exceeding the quantile tends to zero as the sample size increases, and the extreme conditional quantile is thus located in the distribution tails.
LouhichiGirard.pdf (112.13 Ko) Télécharger le fichier
hal-00956351 , version 1 (06-03-2014)
hal-00956351 , version 2 (26-08-2014)
  • HAL Id : hal-00956351 , version 1
Stéphane Girard, Sana Louhichi. On the strong consistency of the kernel estimator of extreme conditional quantiles. 2014. ⟨hal-00956351v1⟩
Collections
UGA
640 Consultations
453 Téléchargements
