On the strong consistency of the kernel estimator of extreme conditional quantiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Nonparametric regression quantiles can be obtained by inverting a kernel estimator of the conditional distribution. The asymptotic properties of this estimator are well-known in the case of ordinary quantiles of fixed order. The goal of this paper is to establish the strong consistency of the estimator in case of extreme conditional quantiles. In such a case, the probability of exceeding the quantile tends to zero as the sample size increases, and the extreme conditional quantile is thus located in the distribution tails.
LouhichiGirard.pdf (113.35 Ko) Télécharger le fichier
hal-00956351 , version 1 (06-03-2014)
hal-00956351 , version 2 (26-08-2014)
Stéphane Girard, Sana Louhichi. On the strong consistency of the kernel estimator of extreme conditional quantiles. Elias Ould Said. Functional Statistics and Applications, Springer, pp.59--77, 2015, Contributions to Statistics, 978-3-319-22475-6. ⟨10.1007/978-3-319-22476-3_4⟩. ⟨hal-00956351v2⟩
640 Consultations
453 Téléchargements
