A quasi-linear algorithm for computing modular polynomials in dimension 2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We propose to generalize the work of Régis Dupont for computing modular polynomials in dimension $2$ to new invariants. We describe an algorithm to compute modular polynomials for any invariants derived from theta constants and prove that this algorithm is quasi-linear.Some properties of the modular polynomials with the quotient of theta constants are analyzed.We report on experiments with our implementation.
QuasiLinAlgModPol.pdf (451.77 Ko) Télécharger le fichier
hal-01080462 , version 1 (06-11-2014)
hal-01080462 , version 2 (26-11-2014)
hal-01080462 , version 3 (02-07-2015)
  • HAL Id : hal-01080462 , version 2
Enea Milio. A quasi-linear algorithm for computing modular polynomials in dimension 2. 2014. ⟨hal-01080462v2⟩
369 Consultations
240 Téléchargements
