A quasi-linear time algorithm for computing modular polynomials in dimension 2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue LMS Journal of Computation and Mathematics Année : 2015
We propose to generalize the work of Régis Dupont for computing modular polynomials in dimension 2 to new invariants. We describe an algorithm to compute modular polynomials for invariants derived from theta constants and prove under some heuristics that this algorithm is quasi-linear in its output size. Some properties of the modular polynomials defined from quotients of theta constants are analyzed. We report on experiments with our implementation.
QuasiLinAlgModPol-Version 2.pdf (465.39 Ko) Télécharger le fichier
hal-01080462 , version 1 (06-11-2014)
hal-01080462 , version 2 (26-11-2014)
hal-01080462 , version 3 (02-07-2015)
Copyright (Tous droits réservés)
  • HAL Id : hal-01080462 , version 3
Enea Milio. A quasi-linear time algorithm for computing modular polynomials in dimension 2. LMS Journal of Computation and Mathematics, 2015, 18, pp.603-632. ⟨hal-01080462v3⟩
369 Consultations
240 Téléchargements
