Invariantization and Polynomial Systems with Symmetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Assuming the variety of a polynomial set is invariant under a group action, we provide a set of invariants that define the same variety. The contribution is about infinite algebraic groups, the case of finite group being previously known. We introduce for those a new definition of the concept of algebraic invariantization. It is based on the construction of rational invariants by Hubert and Kogan (2007), a construction for which we provide here new simplified proofs.
hal01254954v2.pdf (381.32 Ko) Télécharger le fichier
hal-01254954 , version 1 (12-01-2016)
hal-01254954 , version 2 (18-01-2016)
hal-01254954 , version 3 (21-04-2017)
hal-01254954 , version 4 (25-09-2018)
  • HAL Id : hal-01254954 , version 2
Evelyne Hubert. Invariantization and Polynomial Systems with Symmetry. 2016. ⟨hal-01254954v2⟩
Collections
DIEUDONNE
469 Consultations
578 Téléchargements
