Invariant Algebraic Sets and Symmetrization of Polynomial Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
Assuming the variety of a polynomial set is invariant under a group action, we construct a set of invariants that define the same variety. Our construction can be seen as a generalization of the previously known construction for finite groups once we introduce the symmetrizations of a polynomial w.r.t. a section to the orbits of the group action. The symmetrisations are polynomials in a generating set of rational invariants as constructed in [9]. The results have thus to be understood outside of a proper closed invariant variety, independent of the polynomial set considered.
Hal01254954v3.pdf (391.97 Ko) Télécharger le fichier
hal-01254954 , version 1 (12-01-2016)
hal-01254954 , version 2 (18-01-2016)
hal-01254954 , version 3 (21-04-2017)
hal-01254954 , version 4 (25-09-2018)
  • HAL Id : hal-01254954 , version 3
Evelyne Hubert. Invariant Algebraic Sets and Symmetrization of Polynomial Systems. 2017. ⟨hal-01254954v3⟩
469 Consultations
578 Téléchargements
