Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We propose a nonlinear forward Feynman-Kac type equation, which represents the solution of a non-conservative semilinear parabolic Partial Differential Equations (PDE). We show in particular existence and uniqueness in the first part of the article. The second part is devoted to the construction of a probabilistic particle algorithm and the proof of its convergence. Illustrations of the efficiency of the algorithm are provided by numerical experiments.
Parabolic11AoutToSubmit.pdf (514.05 Ko) Télécharger le fichier
hal-01353757 , version 1 (12-08-2016)
hal-01353757 , version 2 (07-07-2017)
hal-01353757 , version 3 (13-09-2017)
hal-01353757 , version 4 (03-10-2018)
Anthony Le Cavil, Nadia Oudjane, Francesco Russo. Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations. 2016. ⟨hal-01353757v1⟩
259 Consultations
358 Téléchargements
