Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We propose a nonlinear forward Feynman-Kac type equation, which represents the solution of a non-conservative semilinear parabolic Partial Differential Equations (PDE). We show in particular existence and uniqueness. The solution of that type of equation can be approached via a weighted particle system.
SubmittedTheoreticalPaperJuly2017.pdf (403.09 Ko) Télécharger le fichier
NonConservativePDE.bib (72.89 Ko) Télécharger le fichier
hal-01353757 , version 1 (12-08-2016)
hal-01353757 , version 2 (07-07-2017)
hal-01353757 , version 3 (13-09-2017)
hal-01353757 , version 4 (03-10-2018)
Anthony Lecavil, Nadia Oudjane, Francesco Russo. Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations. 2017. ⟨hal-01353757v2⟩
259 Consultations
358 Téléchargements
