Stable perfectly matched layers for a class of anisotropic dispersive models. PART I: Necessary and sufficient conditions of stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
In this work we consider a problem of modelling of 2D anisotropic dispersive wave propagation in unbounded domains with the help of perfectly matched layers (PML). We study the Maxwell equations in passive media with the frequency-dependent diagonal tensor of dielectric permittivity and magnetic permeability. An application of the traditional PMLs to this kind of problems often results in instabilities. We provide a recipe for the construction of new, stable PMLs. For a particular case of non-dissipative materials, we show that a known necessary stability condition of the perfectly matched layers is also sufficient. The analysis is done for a constant absorption parameter of the PML. We illustrate our statements with extensive computational experiments.
main.pdf (5.85 Mo) Télécharger le fichier
hal-01356811 , version 1 (19-12-2016)
hal-01356811 , version 2 (10-05-2021)
  • HAL Id : hal-01356811 , version 1
Eliane Bécache, Maryna Kachanovska. Stable perfectly matched layers for a class of anisotropic dispersive models. PART I: Necessary and sufficient conditions of stability. 2016. ⟨hal-01356811v1⟩
422 Consultations
224 Téléchargements
