Stable perfectly matched layers for a class of anisotropic dispersive models. Part I: Necessary and sufficient conditions of stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2017
In this work we consider a problem of modelling of 2D anisotropic dispersive wave propagation in unbounded domains with the help of perfectly matched layers (PML). We study the Maxwell equations in passive media with a frequency-dependent diagonal tensor of dielectric permittivity and magnetic permeability. An application of the traditional PMLs to this kind of problems often results in instabilities. We provide a recipe for the construction of new, stable PMLs. For a particular case of non-dissipative materials, we show that a known necessary stability condition of the perfectly matched layers is also sufficient. We illustrate our statements with theoretical and numerical arguments.
main.pdf (5.85 Mo) Télécharger le fichier
erratum.pdf (46.33 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
Commentaire The Extended Version
hal-01356811 , version 1 (19-12-2016)
hal-01356811 , version 2 (10-05-2021)
Eliane Bécache, Maryna Kachanovska. Stable perfectly matched layers for a class of anisotropic dispersive models. Part I: Necessary and sufficient conditions of stability. ESAIM: Mathematical Modelling and Numerical Analysis, 2017, 51 (6), pp.2399-2434. ⟨10.1051/m2an/2017019⟩. ⟨hal-01356811v2⟩
422 Consultations
224 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
