Reed-Solomon-Gabidulin Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Codes de Reed-Solomon-Gabidulin
We introduce Reed-Solomon-Gabidulin codes which is, at the same time, an extension to Reed-Solomon codes on the one hand and Gabidulin codes on the other hand. We prove that our codes have good properties with respect to the minimal distance and design an efficient decoding algorithm.
gabidulin-hal.pdf (141.78 Ko) Télécharger le fichier
hal-01949409 , version 1 (21-12-2018)
hal-01949409 , version 2 (13-01-2019)
Xavier Caruso, Amaury Durand. Reed-Solomon-Gabidulin Codes. 2018. ⟨hal-01949409v1⟩
229 Consultations
311 Téléchargements
