Reed-Solomon-Gabidulin Codes
Codes de Reed-Solomon-Gabidulin
We introduce Reed-Solomon-Gabidulin codes which is, at the same time, an extension to Reed-Solomon codes on the one hand and Gabidulin codes on the other hand. We prove that our codes have good properties with respect to the minimal distance and design an efficient decoding algorithm.
