Upper bounds on the heights of polynomials and rational fractions from their values - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Let $F$ be a univariate polynomial or rational fraction of degree $d$ defined over a number field. We give bounds from above on the absolute logarithmic Weil height of $F$ in terms of the heights of its values at small integers: we review well-known bounds obtained from interpolation algorithms given values at $d+1$ (resp. $2d+1$) points, and obtain tighter results when considering a larger number of evaluation points.
heights-interpolation.pdf (229.48 Ko) Télécharger le fichier
hal-03226568 , version 1 (14-05-2021)
hal-03226568 , version 2 (16-08-2021)
hal-03226568 , version 3 (09-10-2022)
Jean Kieffer. Upper bounds on the heights of polynomials and rational fractions from their values. 2021. ⟨hal-03226568v1⟩
65 Consultations
251 Téléchargements
