Upper bounds on the heights of polynomials and rational fractions from their values - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Acta Arithmetica Year : 2022
Let $F$ be a univariate polynomial or rational fraction of degree $d$ defined over a number field. We give bounds from above on the absolute logarithmic Weil height of $F$ in terms of the heights of its values at small integers: we review well-known bounds obtained from interpolation algorithms given values at $d+1$ (resp. $2d+1$) points, and obtain tighter results when considering a larger number of evaluation points.
final.pdf (264.27 Ko) Télécharger le fichier
Dates and versions
hal-03226568 , version 1 (14-05-2021)
hal-03226568 , version 2 (16-08-2021)
hal-03226568 , version 3 (09-10-2022)
Identifiers
Cite
Jean Kieffer. Upper bounds on the heights of polynomials and rational fractions from their values. Acta Arithmetica, 2022, 203 (1), pp.49-68. ⟨10.4064/aa210816-26-1⟩. ⟨hal-03226568v3⟩
65 View
251 Download
Share
