On the number of limit cycles in piecewise linear Liénard systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International journal of bifurcation and chaos in applied sciences and engineering Année : 2005
Arnaud Tonnelier
In a previous paper [Tonnelier, 2002] we conjectured that a Liénard system of the form ẋ = p(x) - y, ẏ = x where p is piecewise linear on n + 1 intervals has up to 2n limit cycles. We construct here a general class of functions p satisfying this conjecture. Limit cycles are obtained from the bifurcation of the linear center.
Fichier non déposé
inria-00000583 , version 1 (04-11-2005)
inria-00000583 , version 2 (03-06-2009)
  • HAL Id : inria-00000583 , version 1
Arnaud Tonnelier. On the number of limit cycles in piecewise linear Liénard systems. International journal of bifurcation and chaos in applied sciences and engineering , 2005, 15 (4), pp.1417--1422. ⟨inria-00000583v1⟩
172 Consultations
315 Téléchargements
