On the number of limit cycles in piecewise linear Liénard systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International journal of bifurcation and chaos in applied sciences and engineering Année : 2005
Arnaud Tonnelier
In a previous paper [Tonnelier, 2002] we conjectured that a Liénard system of the form x' = p(x) − y, y' = x where p is piecewise linear on n + 1 intervals has up to 2n limit cycles. We construct here a general class of functions p satisfying this conjecture. Limit cycles are obtained from the bifurcation of the linear center.
Tonnelier_IJBC_2005.pdf (252.01 Ko) Télécharger le fichier
inria-00000583 , version 1 (04-11-2005)
inria-00000583 , version 2 (03-06-2009)
  • HAL Id : inria-00000583 , version 2
Arnaud Tonnelier. On the number of limit cycles in piecewise linear Liénard systems. International journal of bifurcation and chaos in applied sciences and engineering , 2005, 15 (4), pp.1417-1422. ⟨inria-00000583v2⟩
172 Consultations
315 Téléchargements
