Canonical Abstract Syntax Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2006
This paper presents GOM, a language for describing abstract syntax trees and generating a Java implementation for those trees. GOM includes features allowing to specify and modify the interface of the data structure. These features provide in particular the capability to maintain the internal representation of data in canonical form with respect to a rewrite system. This explicitly guarantees that the client program only manipulates normal forms for this rewrite system, a feature which is only implicitly used in many implementations.
gomtomfull.pdf (192.78 Ko) Télécharger le fichier
inria-00000967 , version 1 (06-01-2006)
inria-00000967 , version 2 (20-11-2006)
Antoine Reilles. Canonical Abstract Syntax Trees. [Technical Report] 2006, pp.17. ⟨inria-00000967v1⟩
130 Consultations
360 Téléchargements
