Canonical Abstract Syntax Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents Gom, a language for describing abstract syntax trees and generating a Java implementation for those trees. Gom includes features allowing the user to specify and modify the interface of the data structure. These features provide in particular the capability to maintain the internal representation of data in canonical form with respect to a rewrite system. This explicitly guarantees that the client program only manipulates normal forms for this rewrite system, a feature which is only implicitly used in many implementations.
gomfinal.pdf (203.08 Ko) Télécharger le fichier
architecture.mp (2.33 Ko) Télécharger le fichier
Format : Autre
inria-00000967 , version 1 (06-01-2006)
inria-00000967 , version 2 (20-11-2006)
Antoine Reilles. Canonical Abstract Syntax Trees. 6th International Workshop on Rewriting Logic and Applications - WRLA 2006, Carolyn Talcott and Grit Denker, Apr 2006, Vienna, Austria. ⟨inria-00000967v2⟩
130 Consultations
360 Téléchargements
