Finite Time Bounds for Sampling-Based Fitted Value Iteration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
In this paper we develop a theoretical analysis of the performance of sampling-based fitted value iteration (FVI) for solving large, or infinite state-space Markovian decision problems (MDP) with a generative model. Unlike most previous results, our theoretical guarantees apply to a large class of regressors (e.g. neural networks, adaptive regression trees, kernel machines, locally weighted learning). The bounds derived on the performance of sampling-based FVI make the dependence of loss explicit on the MDP's controllability and smoothness properties, the MDP's relation to the regressor employed and several other algorithmic choices. We discuss the relation of our results to previous results and illustrate some tradeoffs by means of a computer experiment.
savi_1.1.pdf (552.55 Ko) Télécharger le fichier
inria-00120882 , version 1 (18-12-2006)
inria-00120882 , version 2 (19-01-2007)
inria-00120882 , version 3 (09-01-2008)
inria-00120882 , version 4 (05-03-2008)
  • HAL Id : inria-00120882 , version 1
Rémi Munos, Csaba Szepesvari. Finite Time Bounds for Sampling-Based Fitted Value Iteration. [Research Report] 2006, pp.47. ⟨inria-00120882v1⟩
387 Consultations
512 Téléchargements
