Finite Time Bounds for Sampling-Based Fitted Value Iteration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
In this paper we develop a theoretical analysis of the performance of sampling-based fitted value iteration (FVI) to solve infinite state-space, discounted-reward Markovian decision problems (MDPs) under the assumption that a generative model of the environment is available. Our main results come in the form of finite-time bounds on the performance of two versions of sampling-based FVI. The convergence rate results obtained allow us to show that both versions of FVI are well behaving in the sense that by using a sufficiently large number of samples for a large class of MDPs, arbitrary good performance can be achieved with high probability. An important feature of our proof technique is that it permits the study of weighted $L^p$-norm performance bounds. As a result, our technique applies to a large class of function-approximation methods (e.g., neural networks, adaptive regression trees, kernel machines, locally weighted learning), and our bounds scale well with the effective horizon of the MDP. The bounds show a dependence on the stochastic stability properties of the MDP: they scale with the discounted-average concentrability of the future-state distributions. They also depend on a new measure of the approximation capabilities of the function space, the inherent Bellman residual, which reflects how well the function space is ``aligned'' with the essential characteristics of the dynamics of the MDP. The conditions of the main result, as well as the results are extensively discussed and compared to previous theoretical results. Numerical experiments are used to substantiate the theoretical findings.
savi_1.3.pdf (534.13 Ko) Télécharger le fichier
inria-00120882 , version 1 (18-12-2006)
inria-00120882 , version 2 (19-01-2007)
inria-00120882 , version 3 (09-01-2008)
inria-00120882 , version 4 (05-03-2008)
  • HAL Id : inria-00120882 , version 2
Rémi Munos, Csaba Szepesvari. Finite Time Bounds for Sampling-Based Fitted Value Iteration. [Research Report] 2007, pp.47. ⟨inria-00120882v2⟩
387 Consultations
512 Téléchargements
