A locally nameless solution to the POPLmark challenge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The POPLmark challenge is a collective experiment intended to assess the usability of theorem provers and proof assistants in the context of fundamental research on programming languages. In this report, we present a solution to the challenge, developed with the Coq proof assistant, and using the "locally nameless" presentation of terms with binders introduced by McKinna, Pollack, Gordon, and McBride.
report.pdf (407.08 Ko) Télécharger le fichier
inria-00123945 , version 1 (11-01-2007)
inria-00123945 , version 2 (11-01-2007)
  • HAL Id : inria-00123945 , version 1
Xavier Leroy. A locally nameless solution to the POPLmark challenge. [Research Report] 2007, pp.54. ⟨inria-00123945v1⟩
237 Consultations
274 Téléchargements
