A locally nameless solution to the POPLmark challenge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The POPLmark challenge is a collective experiment intended to assess the usability of theorem provers and proof assistants in the context of fundamental research on programming languages. In this report, we present a solution to the challenge, developed with the Coq proof assistant, and using the "locally nameless" presentation of terms with binders introduced by McKinna, Pollack, Gordon, and McBride.
RR-6098.pdf (405.37 Ko) Télécharger le fichier
inria-00123945 , version 1 (11-01-2007)
inria-00123945 , version 2 (11-01-2007)
  • HAL Id : inria-00123945 , version 2
Xavier Leroy. A locally nameless solution to the POPLmark challenge. [Research Report] RR-6098, INRIA. 2007, pp.54. ⟨inria-00123945v2⟩
237 Consultations
274 Téléchargements
