s'authentifier
version française rss feed
inria-00130803, version 3
Evolutionary Epidemic Routing
Sara Alouf () 1, Iacopo Carreras a1, Daniele Miorandi a1, Giovanni Neglia () 1
N° RR-6140 (2007)
Résumé : We introduce a framework which allows forwarding schemes to evolve in order to adapt to changing and a priori unknown environments. The framework is inspired by genetic algorithms: at each node a genotype describes the forwarding scheme used, a selection process fosters the diffusion of the fittest genotypes in the system and new genotypes are created by combining existing ones or applying random changes. This framework is illustrated through a simple case study and simulations are undertaken to evaluate its performance.
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : Wireless networks – delay-tolerant networks – epidemic forwarding – evolving protocols – genetic algorithms
  • Référence interne : RR-6140
  • Versions disponibles :  v1 (14-02-2007) v2 (12-03-2007) v3 (23-05-2007)
  • inria-00130803, version 3
  • oai:hal.inria.fr:inria-00130803
  • Contributeur :
  • Soumis le : Mardi 22 Mai 2007, 16:34:27
  • Dernière modification le : Jeudi 2 Octobre 2008, 16:21:12
tous les articles de la base du CCSd...
