Evolutionary Epidemic Routing - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2007
We present a framework which allows forwarding schemes to evolve in order to adapt to a changing and a-priori unknown environment. The framework is inspired by genetic algorithms: at each node a genotype describes the forwarding scheme, a selection process fosters the diffusion of the fittest genotypes among the nodes, new genotypes are created by combining existing ones or applying random changes.
RR-6140.pdf (160.06 Ko) Télécharger le fichier
Dates and versions
inria-00130803 , version 1 (14-02-2007)
inria-00130803 , version 2 (12-03-2007)
inria-00130803 , version 3 (22-05-2007)
Identifiers
  • HAL Id : inria-00130803 , version 2
Cite
Sara Alouf, Iacopo Carreras, Daniele Miorandi, Giovanni Neglia. Evolutionary Epidemic Routing. [Research Report] RR-6140, 2007. ⟨inria-00130803v2⟩
Collections
INRIA-RRRT
174 View
211 Download
Share
