Evolutionary Epidemic Routing
We present a framework which allows forwarding schemes to evolve in order to adapt to a changing and a-priori unknown environment. The framework is inspired by genetic algorithms: at each node a genotype describes the forwarding scheme, a selection process fosters the diffusion of the fittest genotypes among the nodes, new genotypes are created by combining existing ones or applying random changes.
