Non-linear estimation is easy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Int. J. Modelling, Identification and Control Année : 2007
Non-linear state estimation and some related topics, like parametric estimation, fault diagnosis, and perturbation attenuation, are tackled here via a new methodology in numerical differentiation. The corresponding basic system theoretic definitions and properties are presented within the framework of differential algebra, which permits to handle system variables and their derivatives of any order. Several academic examples and their computer simulations, with on-line estimations, are illustrating our viewpoint.
easy.pdf (1.02 Mo) Télécharger le fichier
inria-00158855 , version 1 (29-06-2007)
inria-00158855 , version 2 (24-10-2007)
  • HAL Id : inria-00158855 , version 1
Michel Fliess, Cédric Join, Hebertt Sira-Ramirez. Non-linear estimation is easy. Int. J. Modelling, Identification and Control, 2007. ⟨inria-00158855v1⟩
1707 Consultations
2014 Téléchargements
