Non-linear estimation is easy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Modelling, Identification and Control Année : 2008
Non-linear state estimation and some related topics, like parametric estimation, fault diagnosis, and perturbation attenuation, are tackled here via a new methodology in numerical differentiation. The corresponding basic system theoretic definitions and properties are presented within the framework of differential algebra, which permits to handle system variables and their derivatives of any order. Several academic examples and their computer simulations, with on-line estimations, are illustrating our viewpoint.
easy-arx.pdf (1.14 Mo) Télécharger le fichier
inria-00158855 , version 1 (29-06-2007)
inria-00158855 , version 2 (24-10-2007)
Michel Fliess, Cédric Join, Hebertt Sira-Ramirez. Non-linear estimation is easy. International Journal of Modelling, Identification and Control, 2008, Special Issue on Non-Linear Observers, 4 (1), pp.12-27. ⟨10.1504/IJMIC.2008.020996⟩. ⟨inria-00158855v2⟩
1711 Consultations
2022 Téléchargements
