Helly-type theorems for approximate covering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Let F be a covering of a unit ball U in Rd by unit balls. We prove that for any epsilon >0, the smallest subset of F leaving at most a volume epsilon of U uncovered has size O(epsilon^((1-d)/2)polylog 1/epsilon). We give an example showing that this bound is tight in the worst-case, up to a logarithmic factor, and deduce an algorithm to compute such a small subset of F. We then extend these results in several directions, including covering boxes by boxes and visibility among disjoint unit balls in R3.
Mots clés
RR.pdf (234.76 Ko) Télécharger le fichier
inria-00179277 , version 1 (15-10-2007)
inria-00179277 , version 2 (05-11-2007)
inria-00179277 , version 3 (05-11-2007)
  • HAL Id : inria-00179277 , version 1
Julien Demouth, Olivier Devillers, Marc Glisse, Xavier Goaoc. Helly-type theorems for approximate covering. [Research Report] 2007, pp.12. ⟨inria-00179277v1⟩
231 Consultations
178 Téléchargements
