Helly-type theorems for approximate covering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Let F be a covering of a unit ball U in Rd by unit balls. We prove that for any epsilon >0, the smallest subset of F leaving at most a volume epsilon of U uncovered has size O(epsilon^((1-d)/2)polylog 1/epsilon). We give an example showing that this bound is tight in the worst-case, up to a logarithmic factor, and deduce an algorithm to compute such a small subset of F. We then extend these results in several directions, including covering boxes by boxes and visibility among disjoint unit balls in R3.
Mots clés
RR-6342.pdf (430.89 Ko) Télécharger le fichier
inria-00179277 , version 1 (15-10-2007)
inria-00179277 , version 2 (05-11-2007)
inria-00179277 , version 3 (05-11-2007)
  • HAL Id : inria-00179277 , version 2
Julien Demouth, Olivier Devillers, Marc Glisse, Xavier Goaoc. Helly-type theorems for approximate covering. [Research Report] RR-6342, 2007, pp.12. ⟨inria-00179277v2⟩
231 Consultations
178 Téléchargements
