Fairness Issues When Transferring Large Volumes of Data on High Speed Networks With Router-Assisted Transport Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This report presents improvements of the eXplicit Control Protocol (XCP) in order to support fairness between XCP and TCP flows. Our mechanisms are based on two main components: estimations of the resources needed by XCP, and limitation of the resources taken by TCP. The set of simulations shown in this report proves that we can guarantee a fairness level between XCP and TCP. We think that our TCP-XCP fairness mechanism can be perfectly applied for Long Distance Data Grids, where senders need to transfer large volumes of data.
report-hsn.inria.pdf (470.68 Ko) Télécharger le fichier
inria-00195675 , version 1 (11-12-2007)
inria-00195675 , version 2 (13-12-2007)
  • HAL Id : inria-00195675 , version 1
Dino Martín Lopez Pacheco, Laurent Lefèvre, Cong-Duc Pham. Fairness Issues When Transferring Large Volumes of Data on High Speed Networks With Router-Assisted Transport Protocols. [Research Report] 2007, pp.16. ⟨inria-00195675v1⟩
150 Consultations
258 Téléchargements
