On mean discounted numbers of passage times in small balls of Ito processes observed at discrete times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The aim of this note is to prove estimates on mean values of the number of times that Itô processes observed at discrete times visit small balls in $\er^d$. Our technique, in the infinite horizon case, is inspired by Krylov's arguments in~\cite[Chap.2]{kry80}. In the finite horizon case, motivated by an application in stochastic numerics, we discount the number of visits by a locally exploding coefficient, and our proof involves accurate properties of last passage times at 0 of one dimensional semimartingales.
RR-6813.pdf (281.4 Ko) Télécharger le fichier
inria-00347610 , version 1 (16-12-2008)
inria-00347610 , version 2 (27-01-2009)
inria-00347610 , version 3 (09-05-2009)
  • HAL Id : inria-00347610 , version 2
Frédéric Bernardin, Mireille Bossy, Miguel Martinez, Denis Talay. On mean discounted numbers of passage times in small balls of Ito processes observed at discrete times. [Research Report] RR-6813, 2009, pp.19. ⟨inria-00347610v2⟩
212 Consultations
166 Téléchargements
