On mean discounted numbers of passage times in small balls of Ito processes observed at discrete times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Communications in Probability Année : 2009
The aim of this note is to prove estimates on mean values of the number of times that Itô processes observed at discrete times visit small balls in $\er^d$. Our technique, in the infinite horizon case, is inspired by Krylov's arguments in~\cite[Chap.2]{kry80}. In the finite horizon case, motivated by an application in stochastic numerics, we discount the number of visits by a locally exploding coefficient, and our proof involves accurate properties of last passage times at 0 of one dimensional semimartingales.
RR-6813.pdf (297.69 Ko) Télécharger le fichier
inria-00347610 , version 1 (16-12-2008)
inria-00347610 , version 2 (27-01-2009)
inria-00347610 , version 3 (09-05-2009)
  • HAL Id : inria-00347610 , version 3
Frédéric Bernardin, Mireille Bossy, Miguel Martinez, Denis Talay. On mean discounted numbers of passage times in small balls of Ito processes observed at discrete times. Electronic Communications in Probability, 2009, 14, pp.19. ⟨inria-00347610v3⟩
212 Consultations
166 Téléchargements
