A criterion for hypothesis testing for stationary processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Given a discrete-valued sample X_1... X_n we wish to test whether it was generated by a process belonging to a family H_0, or it was generated by a process outside H_0. All process distributions are assumed stationary ergodic, and no further probabilistic or parametric assumptions are made. We require the Type I error of the test to be uniformly bounded, while the probability of Type II error has to tend to zero as the sample size increases. For this notion of consistency we provide necessary and sufficient conditions on the family H_0 for the existence of a consistent test. This criterion is illustrated with applications to testing for a membership to parametric families, generalizing some existing results.
1c.pdf (142.33 Ko) Télécharger le fichier
inria-00389689 , version 1 (29-05-2009)
inria-00389689 , version 2 (30-05-2009)
inria-00389689 , version 3 (19-10-2009)
inria-00389689 , version 4 (26-12-2014)
  • HAL Id : inria-00389689 , version 1
  • ARXIV : 0905.4937
Daniil Ryabko. A criterion for hypothesis testing for stationary processes. [Research Report] 2009. ⟨inria-00389689v1⟩
Collections
LIFL
285 Consultations
203 Téléchargements
