A criterion for hypothesis testing for stationary processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Given a finite-valued sample $X_1,\dots,X_n$ we wish to test whether it was generated by a stationary ergodic process belonging to a family $H_0$, or it was generated by a stationary ergodic process outside $H_0$. We require the Type I error of the test to be uniformly bounded, while the type II error has to be mande not more than a finite number of times with probability 1. For this notion of consistency we provide necessary and sufficient conditions on the family $H_0$ for the existence of a consistent test. This criterion is illustrated with applications to testing for a membership to parametric families, generalizing some existing results. In addition, we analyze a stronger notion of consistency, which requires finite-sample guarantees on error of both types, and provide some necessary and some sufficient conditions for the existence of a consistent test. We emphasize that no assumption on the process distributions are made beyond stationarity and ergodicity.
1c.pdf (161.29 Ko) Télécharger le fichier
inria-00389689 , version 1 (29-05-2009)
inria-00389689 , version 2 (30-05-2009)
inria-00389689 , version 3 (19-10-2009)
inria-00389689 , version 4 (26-12-2014)
  • HAL Id : inria-00389689 , version 3
  • ARXIV : 0905.4937
Daniil Ryabko. A criterion for hypothesis testing for stationary processes. [Research Report] 2009. ⟨inria-00389689v3⟩
Collections
LIFL
285 Consultations
203 Téléchargements
