Robust stop-and-go control strategy: an algebraic approach for nonlinear estimation and control
This paper describes a robust stop-and-go control strategy for vehicles. Since sensors used in a real automotive context are generally low cost, measurements are quite noisy. Furthermore, many vehicle/road interaction factors (road slope, rolling resistance, aerodynamic forces) are very poorly known. Hence, a robust strategy to noise and parameters is proposed within the same theoretical framework: algebraic nonlinear estimation and control techniques. On the one hand, noisy signals will be processed in order to obtain accurate derivatives, and thereafter, variable estimates. On the other hand, a grey-box closedloop control will be implemented to reject all kind of disturbances caused by exogenous parameter uncertainties.
