Robust stop-and-go control strategy: an algebraic approach for nonlinear estimation and control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Vehicle Autonomous Systems Année : 2009
This paper describes a robust stop-and-go control strategy for vehicles. Since sensors used in a real automotive context are generally low cost, measurements are quite noisy. Furthermore, many vehicle/road interaction factors (road slope, rolling resistance, aerodynamic forces) are very poorly known. Hence, a robust strategy to noise and parameters is proposed within the same theoretical framework: algebraic nonlinear estimation and control techniques. On the one hand, noisy signals will be processed in order to obtain accurate derivatives, and thereafter, variable estimates. On the other hand, a grey-box closedloop control will be implemented to reject all kind of disturbances caused by exogenous parameter uncertainties.
IJVAS.pdf (1.44 Mo) Télécharger le fichier
inria-00419445 , version 1 (23-09-2009)
inria-00419445 , version 2 (25-09-2009)
Jorge Villagra, Brigitte d'Andréa-Novel, Sungwoo Choi, Michel Fliess, Hugues Mounier. Robust stop-and-go control strategy: an algebraic approach for nonlinear estimation and control. International Journal of Vehicle Autonomous Systems, 2009, 7 (3/4), pp.270-291. ⟨10.1504/IJVAS.2009.033264⟩. ⟨inria-00419445v2⟩
741 Consultations
1102 Téléchargements
